#710605 08/02/03 08:52 PM
9
I have a 96 mystique with a 2.5" exhaust. I have a glasspack that I got two years ago and I think it might have failed. I have posted many times about the performance of my car and it has gotten worse, I cant rev it past 3k rpms. I have replaced wires, plugs, O2, fuel filter, MAF, air filter, etc. There is a loud hissing sound coming from what seems that cat (Just around the bottom of the car in that area). Sounds like a sucking in of air but it could be blowing. But what I think it is now is that my glasspack failed, is this possible? And if it failed would it restrict the exhaust? The engine just basically seems to be getting choked when I try to rev it.
#710606 08/02/03 08:59 PM
I would think the glasspack would likely just blow its contents out.
Why don't you suspect the cat of being plugged?
"Cobb - It's not just for corn anymore!"
#710607 08/02/03 09:05 PM
9
I sure hope its not the cat, I have 80460 miles on it, just a little bit out of warranty
#710608 08/02/03 09:46 PM
H
H
Originally posted by 96mystiquezetec:
... There is a loud hissing sound coming from what seems that cat (Just around the bottom of the car in that area). Sounds like a sucking in of air but it could be blowing. ...
Best check your DPFE hoses. If off, sure sign pre-cats plugged. You should smell/hear exhaust in engine compartment if this problem exists. Other restrictions in exhaust system can cause loss of power, however.
#710609 08/03/03 05:54 PM
H
H
DPFE = Differential Pressure Feedback EGR sensor. It has 2 short hoses that come from the exhaust manifold-to-EGR tube. On your car it is mounted on firewall at about the center of car (if Fig 6.26 in Haynes manual is accurate).
