#710534 08/02/03 07:25 PM
O
O
ok i just bought all leather interior for my 99 lx and the seats orginally came out of a 98 svt. however the driver front seat is all power and the passenger is not. i noticed under the seat there are a bunch of wires and at the end of the wires there is a plug with two wires. is this just power and ground? if so can i just run it to my battery or acc? or will it not work at all? thanks
1999 Contour Vetech 5 Speed. Added Leather seats, painted dash pieces, new sound system.
#710535 08/02/03 11:01 PM
Should be your power seat connector. Plug it in and try. If that doesn't work, run + and ground and splice into the wire harness yourself.
2000 Silver Frost SVT # 1637/2150 D.O.B. 01/14/2000
#710536 08/03/03 05:46 AM
I
I
should be 2 connecters under there somewhere. both the same basic shape, but 2 different sizes. the bigger one is for the power seat, the smaller one is for the seatbelt.
contours, deloreans & fiats, oh my!
#710537 08/03/03 05:22 PM
O
O
i just installed my seats yesterday thanks for the info. i found the two plugs like you said i plugged the one into the seatbelt like you said then theres still the other one for power seats should i run that straight to my battery or tap into somehting else like my acc. if i go straight to my battery will it drain it when my cars off? Or where else would i run it to or what wires should i tap into? thanks alot
#710538 08/04/03 02:35 AM
I
I
that plug should already be run into the harness and ready to go. If you've plugged in and don't have power, check your fuses.
