Posts: 2,676 |
no, Flecha is right, 2.25, trust me, I ordered a resonator and had to size it just right. . .
Posts: 1,731 |
my bad.. I was under the wrong impression.. checked up on it.. it is indeed 2.25"
Black 98.5 SVT
"Kellie"
First rule of italian driving: What is behind you, DOESN'T matter
Posts: 1,469 |
Bassani made same power gains as Brullen...on mild moderately modded 2.5L. With 3L, FI, maybe heavy 2.5L mod etc...2.5" better. Downside to Brullen is fitment issues that a number on GB reported. Did that get resolved?
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Posts: 66 |
If you go with bassani get the magnaflow resonator. No rasp at all.
-Bassani exhaust *Track #'s*
-Sho Shop intake 14.986@92.16
-CTA inlet pipe
-MSDS headers w/ Y-pipe
-Ground Control Coilovers
-Koni Adjustable Struts
- Quaife, fidanza, spec 3
-DMD
-Apexi S-AFC
Posts: 9,602 |
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,731 |
Originally posted by DemonSVT: Get true duals???
$$$$$$$$$$$$$$$ CHA CHING $$$$$$$$$$$$$$$$$
Black 98.5 SVT
"Kellie"
Posts: 1,272 |
Actually Dan, I think my car was the only one (from what I can tell) that didn't have major fitment issues from the GB. Then again, I had the only 2000 "loud" system ordered....I think(the 98, some 99's have different bends due to the gas tank placement). Alex and SVTCuervo were very easy to deal with, so I would have no issues ordering from them in the future. Plus, according to them, it was an issue with the company that custom bent the pipes that has been rectified for any future customers.
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA
NECEG "Troll"
formerly owned 2000 SVT Contour, with all kinds of goodies;)
Posts: 873 |
Originally posted by Kevdogg410: Originally posted by DemonSVT: Get true duals???
Actually I believe Demon built his for around $300...though it doesn't follow the bends around the passenger cabin. However, it still looks fine from the pictures that I've seen.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 2,211 |
Originally posted by wontgrowup: Actually Dan, I think my car was the only one (from what I can tell) that didn't have major fitment issues from the GB. Then again, I had the only 2000 "loud" system ordered....I think(the 98, some 99's have different bends due to the gas tank placement). Alex and SVTCuervo were very easy to deal with, so I would have no issues ordering from them in the future. Plus, according to them, it was an issue with the company that custom bent the pipes that has been rectified for any future customers.
That is correct and also the Brullen makes higher gains than the Bassani. It was Dyno proven for about 3 more HP. Of course many factors can contribute to dyno numbers, but these are back to back to back to back runs with consistent numbers. Also Brullen sounds sooooooooooooooooooooooooooooo gooooooooooooooooooooood
oh and mine went on with out a singel fitment issue and if you also get the Equal Length'd Brullen Y-pipe, you can't beat the sound or performance. ABSOLUTLEY NOOOOOOOOOOOOOOOO RASP
Posts: 1,469 |
Bassani made 7 HP more than stock at peak (more at some other points on curve). Brullen claims 10...HOWEVER, on their dynos they ran the Brullen to higher RPMs...with "stock" they quit several hundred RPM earlier, and the curve was still climing (so stock would probably have had a better number had they run it all the way). At the last data point where stock and Brullen could be compared the difference was.....7 HP. And the HP & T gains across the powerband were virtually superimposable. So I think power gains are the same...certainly when dyno error factored in. I do not buy the 3 HP more..
