I have an Alpine MRV 100, which suddenly quit working last week. It would blow the fuse on the amp the second I put it in.
I took it apart, and messed with it usng a multimeter. I found that all the transsistors on one side of the amp that are bolted to the heatsink, whick attaches to the amp casing, were shorting to ground through the screws that attach them to the heatsink. I unbolted the heatsink from the parts and the casing, and just for sh!ts and giggles, hooked it back up in the car, to see if that was the problem. One transistor immediately went up in smoke, and burst into flames (pretty cool
I figured since the amp was now trash, I cut the offending transistor off and hooked it back up just to see what else would possibly happen. The damn thing works, with no noticable volume differences or power output. Sounds the same, works the same. After bolting all the other transistors to the heatsink and putting everything back together, no problems. I ran the amp as hard as I could stand it, and it took the abuse and never even got warm.
My question is, how long will this amp continue to function, and am I risking a fire or something? My power cable is fused 6 inches from the battery, so Im not too worried abbout that.
