Posts: 148 |
After having removed the lug nuts on my 14" steel wheel, right front, the wheel won't come off.It appears to be seized/rusted on.I am in the process of changing over to some alloys that I found in the classifides.Any ideas? The wheel was off about four months ago and I did hit a curb. I'll be off to the tire store in a day or two,but I want to get them off before the tire guys, in order that I may clean up the mating surface.
stock 95 LX,6cyl ATX
Posts: 178 |
i had a hell of a time getting my front left off justa bit of rust under the rim between the rotor it all it was, brute force
Posts: 9,178 |
I had the same thing happen. I used a rubber hammer to break it loose.
Posts: 148 |
My son is 6'3", 220, played Jr hockey..I'll dangle some food his way..he gets the tire off, he eats.
Posts: 47 |
Never tried this on a Contour, but it's worked on other cars:
Put your lug nuts back on, but leave them a turn or so loose. Take it off the jacks and start it up. Move it back and forth a few feet and turn wheels while moving. Jack it up, it should be loose. Good luck, and be careful!
Al
Posts: 1,040 |
I've successfully used a short piece of 2x4, hitting tire on inside, rotate, hit again: repeat as necessary.
Posts: 1,375 |
Kick the tire or grab something heavy like another tire and throw it agianst it, Be sure to grab something that won't scratch it of course
99 SVT Tropic Green #151 of 503/ 2760 total Born on 10/07/98 Adopted 7/15/00 LETS GO RANGERS (looking good this year)
Posts: 284 |
WD-40... spray it let it sit a minute and kick it lol
~*TJ*~ 97 GL Sport Zetec ~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
Posts: 46 |
 Just leave the lug nuts off and drive it around until the wheel comes off.. No more worries
John 1996 Ford Contour 2.0 Liter Turbo 5spd/ Pioneer 6.5" Television / DEH8000 CD Player/ Darkened Tail Lights/Shaved Emblems/ 17" Ultra Nocturno Rims 205/40-17's/ Custom Painted Cowl,Wipers, And Mirror Mounts/ Shaved Front Tag Holes And Window Squirters/ High Flow Catalytic Converter/Ford 9mm Spark Plug Wires/ Custom Exhaust Catalytic Back/Hyper White Lights/ Superchip/K&N Air Filter/Shortened Fubo Antenna/Billet Rear Antenna/ BNMotorsports White Face Gauge W/ Red Numerics And Matching HVAC Panel/H&R Coil Over Springs.
Posts: 29 |
AlKraut said, "Never tried this on a Contour, but it's worked on other cars:
Put your lug nuts back on, but leave them a turn or so loose. Take it off the jacks and start it up. Move it back and forth a few feet and turn wheels while moving. Jack it up, it should be loose. Good luck, and be careful!"
I know this works and was a common practice for loosening up the rear brake drums for maintenance on those "old" cars. It definitely works to free up a rim; I had to do this on my boat trailer about two weeks ago. John 98 SVT
John Black '98 CSVT #2000 of 6535 Sometimes good, sometimes bad Sometimes hate it, mostly love it No mods other than 225/45-17 tires
