RMk Offline OP
While installing an open K&N/heat shield, I had a little bit of trouble getting the heat shield to fit properly... the culprit was the rubber transaxle mount insert. The bolt had broken off and it was sitting higher than it normally would be. The question is this... is this the part that Energy Suspension's poly insert replaces? I was going to buy those anyway and now I have a good reason. laugh
.RMk..
'99 SVT, Silver Frost
Open K&N w/ heat shield.
Nope, the ES insert is only for the front mount, just get a 'high tensile' bolt to replace the broken one and it will be fine...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
