gray Offline OP
Hi there,
I did a search and didn't find any discussion on the spray wax called "Speed Bead" wax by Stoner. Does anyone have an opinion out this product? I've used it once and can't tell if it is any better than the regular hard or liquid wax. It does make the black paint really sparkle. Is this some revolutionary product? It is incredibly easy to use. I waxed the entire car in 10 minutes!! Please give me your opinion! Thanks.
1997 Black Contour SE with all the options
Originally posted by gray:
Hi there,
Never used it myself, never even heard of it.
Justin Schmidt 2000 SVT Tour #1620 of 2150 Born 1/15/2000
I find that those 'types' of waxes that are marketed as speedy don't last very long at all.
I have never heard of that product from Stoner before. But, hey, if it works for you then all the power to you.
'99 Silver Frost.SE.V6.MTX Drop-in K&N / Masked rear Reflector st200/Eibach / SVT E1's FMS Wires / ES Rear Bushings
I have been using it since May and I love it. It is speedy like you said and water beads up just as well as any other product. I do use it quite frequently because it is so easy and does not last as long as a Maguires or Mothers.
"I'm not above the law, I'm beyond the law" 1999 CSVT Toreador Red Magnaflow Resonator and large K&N
gray Offline OP
Thanks. I noticed it didn't seem to smooth away as many imperfections as the regular stuff but I do like the ease of use and the look it provides. Take care.
My boss gave me a can of both Speed Bead and Bead Max to try out. I've tried both and it does go on easy and seems to do a good job, but I've got so much Meguiars on right now, that I just don't know. If it works for you, stick with it, but atleast get the Bead Max because I'd say it lasts longer, read your bottle and see what it says its for, then you'll know what I mean Good luck with your "stoner" products!
