#62461 06/04/02 02:55 PM
JHAT Offline OP
My car was having trouble shifting. I added trans fluid, which help for a few hours. When I hit the interstate the O/D OFF light started blinking. Any ideas as to why? Did I put in too much fluid? This is getting annoying.
#62462 06/04/02 04:58 PM
W
W
What year and model is your car? How many miles are on your car? I assume it is an automatic transmission.
#62463 06/04/02 05:22 PM
JHAT Offline OP
Auto 1998 SE 47k miles
#62464 06/04/02 08:20 PM
Take it to a shop. When the OD light flashes somethings wrong and it's probably overheating. I've got a 98 'Tour with a bad ATX (torque convertor) right now, and driving it just 60 more miles after the first signs burned the clutches out... more $$$ out of my wallet. frown
The ATX's in our cars are dogs and are prone to overheating. I'm installing a Level 10 rebuild kit and external tranny cooler next week. I reccommend the aftermarket cooler to everyone with an ATX.
BTW, how's the fluid look? If it's burnt (brown, strong smell) you're due for a rebuild. By that point it's too late. If it's still pink you may be able to pour in some Tranny Dr. or something and pull through. Sounds like your clutches, though... if you put too much fluid in the tranny, it won't shift right. Same thing if it's very low.
1998 Contour Sport V6, Black
*Cold air induction
*Powdercoated intake manifold (more powdercoating coming soon)
*Blue headlights, foggies, and signals (no reflectors)
*CEG stickers & removed door moldings
1994 Ford Aspire 4-door, looks like a big egg
*64 hp 4-cyl
*5 speed
*"13 steel rims with go-cart tires
*74 mph top speed
*I'm going to auto-x the thing (but not compete)
#62465 06/04/02 08:30 PM
JHAT Offline OP
Well I think the fluid is too high, would that cause the O/D light to flash?
#62466 06/04/02 09:04 PM
JHAT Offline OP
How much to replace to a nice new improved tran
#62467 06/05/02 02:03 AM
Ford will put a reman unit in for about $2200. Rebuilds will usually run $1100 to $2000. Like I say, aftermarket cooler = good idea. wink
*Cold air induction
*64 hp 4-cyl
*5 speed
*74 mph top speed
#62468 06/05/02 02:06 AM
Try Levelten.com. They specialize in ATX upgrades and I hear they do an awesome job on our cars. I'm ordering their rebuild kit this week and having a local shop install it for $1100. Total $1575... not bad at all (considering).
*Cold air induction
*64 hp 4-cyl
*5 speed
*74 mph top speed
#62469 06/05/02 02:11 AM
9
9
My cousin has the exact same car. Her ATX blew out, was over $1100 to fix. Plan on spending at least a grand on your tranny
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
#62470 06/05/02 03:32 PM
JHAT Offline OP
Thanks for the info. I am really hoping I just overfilled it
