...talk about a bad day...
Started with a speeding ticket this morning...then girlfriend decides we should see other people...just a bad day at work...then my clutch decides to mess up.
Anyways, I just had a new Grizzly clutch put in about 2 months ago along with pressure plate, relaease bearing/slave cylinder. Today on my way home from work just as I was pulling into town my clutch pedal sinks all the way to the floor. I was able to drive it home but it was to say the least difficult. It engages when the pedal is almost to the floor and it only engages about 50% of the time.
Dont know if this could be related but ever since the new clutch was put in there has been a squeaking/clicking noise coming from the clutch pedal whenever it would engage in a gear.
I got lucky on the clutch installation...my trans was out for the 3rd gear syncro replacement and they put the clutch in at no charge. But I really dont need a $1000+ repair bill.
I'm sure the dealership will say it Grizzly's fault and Grizzly will say it was a bad install on Fords part. Either way I'll probably get screwed.
I'm going to attempt to drive it to the dealership in the morning...just gonna pray I make it.
Bad install or did I toast the Grizzly clutch in only 1000 miles?
Any help would be appreciated.
EDIT: 99 SVT if it makes a difference
-neal
