Posts: 70 |
Anyone experience this when they fill up? Every time I go to a gas station to fill up it takes me like 10 minutes to do it. I dont know if its the design of the tank or what but the automatic fuel cutoff in the pump seems to like to go off every time I pump gas which means I have to sit there holding the pump less then half way pumping gas like a gallon per hour just wondering if this happends to anyone else?
"Evolution Zero" B&M short throw Msds headers & y pipe Borla exhaust Smoked Tailights *Coming Soon* DMD
Posts: 345 |
Known problem, open recall. Check with the dealer.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 78 |
Happens to me every so often and i know what you mean, it sucks...only fix is through the dealer far as i know...
..VERRUCKT 4 LIFE..
98 Contour SE V6 Auto BAT Intake
02 Pontiac Grand prix
Posts: 1,040 |
You haven't stated your car info, but my '98 was subject to "recall" on this. My '97 doesn't have the problem (different fuel neck design - bigger air hole).
Posts: 311 |
So that explains it! I just thought I was choosing the wrong pumps. :p
1998 Contour Sport V6, Black *Cold air induction *Powdercoated intake manifold (more powdercoating coming soon) *Blue headlights, foggies, and signals (no reflectors) *CEG stickers & removed door moldings -------------------------------- 1994 Ford Aspire 4-door, looks like a big egg *64 hp 4-cyl *5 speed *"13 steel rims with go-cart tires *74 mph top speed *I'm going to auto-x the thing (but not compete)
Posts: 36 |
One tip: When taking it in for the recall. Have your tank near empty. They must lower the tank from the car to replace the fuel flapper valve and if you have gas in the tank they pump it out and then pump it back in after they are done with the work. Having an empty tank not only gets the job done quicker but then they aren't pumping a bunch of crap back into your tank.
d ~ 98 SVT E1 #6196 of 6535
Posts: 3,636 |
My tip is make sure they do it right the first time.
About a year ago, I had this fix done to my car. Of course I picked it up at closing time. Yes, the problem with the pump shutting off prematurely was fixed, replaced by a new problem, that the fuel would leak out of the top of the tank.
Of course, service department is now closed, so I left voicemail, and my car leaking on their driveway.
Took my keys and met them at a bit after 8 to move my car from infront of the doors.
Service manager came with me on the next trip to the gas station.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 6 |
I have had the same problem on my '95 Mystique. I got the double whammy, though, because I live in NJ and don't have self-serve. So basically I just have to hope the attendant doesn't lost patience.
Anyway, I looked for a recall on this and all I found were recalls relating to leaks or fumes. I didn't see anything else. Can someone post a recall number or a link where I can find it? This has been by far my biggest pet peeve since buying the car.
Posts: 234 |
I have the same problem and I just made a call and with my VIN they said there is no recall for what supersvt described.
1999 Silver Ford SVT Contour 1994 Black Chevy Caprice 9C1
Posts: 767 |
From what I gather it is not a recall, but a TSB or 'technical service bulletin'. Its more of an annoyance than a safety hazard and therefore Ford is probably unwilling to bite the bullet. Thus if you want it fixed you will have to pay for it. There is some good info/tips in this thread: Earlier thread Here is what i posted in that thread that may make your trips to the gas station a bit more bearable (it worked for me): Here is a tip: When inserting the nozzle, be sure not to insert with full force and don't press it up against the gas tank. I always thought it was a good idea to press it up to create a "seal" with the rubber surround of the nozzle...instead just insert it like 4/5 of the way inside...pretty much all the way but not completely... (make sure it IS inside tho! ) and its should be MUCH easier to fill your tank up.
1998 E0 Ford Contour SVT Built on 8/19/97 -- #3101/6535 Silver Frost/Midnight Blue * New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
