Posts: 165 |
OK guys... Problem #1-The car is still running at the "L" after back flush and 180 thermostat. Problem #2-It takes me over a mile to get up to 60 mph. She accelerates weak up to 3000 RPM and then she doesn't want to go any higher  . Things I still need to do: fuel filter, PCV, and I haven't checked the EGR system at all. Or the coil. Could these really keep the car running this bad? Also, can I change the fuel filter without removing the rear wheel? My rims have a nut that requires an adapter and it didn't come with the car  . Any help would be most appreciated. This car is starting to get kind of frustrating
Contour--It will make a master mechanic out of you!
95 LX MTX Bolt-ons
95 Neon SOHC ATX
77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
Posts: 3,345 |
Have you changed the spark plugs and plug wires? That might be a cause of your bad acceleration. Regarding the fuel filter, all you have to do it is back the car up onto some ramps, or put it on jackstands. Look under the car a few inches in front of the passenger side rear wheel and a few inches from the outside edge of the car. You should see a cylinder shaped object with a hose coming out of each end and held up by a metal clamp. That is your fuel filter. Be careful removing it though because it is full of gas. I hope I was some help.  Oh and remember to block your front wheels before getting under the car. Very important.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Posts: 165 |
Originally posted by Bullet: Very important.
That cracked me up! Don't know why...
Changed the fuel filter today, not too hard. If you put the caps from the new one on the old one, you spill less gas . I changed the plug wires last week, and the plugs looked pretty new. I got the new PVC valve, and am procrastinating on putting it in. Could it be my timing is off? And if that is the case, can I correct it myself, or do I need to have someone time it for me?
How about the fact the the gas has been in the car for 5 months
95 LX MTX Bolt-ons
95 Neon SOHC ATX
Posts: 21,653 |
Your timing could be off and you can set it yourself, but it's not fun and it takes some time.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,094 |
If it was/is the EGR you would definitely be getting a CEL. Mine threw one at 90K for the first time ever and it was the EGR sensor. I would say check the fuel filter.
'95 GL White
I've got mods.
Posts: 79 |
Im in the same boat with you, my car does the exact same thing. I got my timing belt replaced, drive belt, and water pump replaced by ford. This did NOT fix the problem. Replaced MAF and fuel filter, NO fix. This has been a problem for me for about 8 months, so I hope you can find the fix where I cannot. Good luck!
Posts: 59 |
my car has the same problem with the running hot. i changed the thermostate, the water pump, flushed the system, and it still runs hot. now my friends car has a sticker saying it has to have a certin type of antifrezze. is there something i dont know and there is a certin type the contour needs. just a thought. i am lost and dont know what eles to do. i just drive and watch the gage i know that not good for the car but what eles can i do. o and the only other thing i can think of is the head or the head gasget but i am not about to spend the money and that not be the problem. any help would be nice thanks. sorry i suck at spelling.lol.
Posts: 21,653 |
Contour needs the green type (unless car is new, then dexcool is an option).
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: Contour needs the green type (unless car is new, then dexcool is an option).
Dexcool is crap!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
