My air conditioner clutch will not engage (therefore no AC). The radiator fan also does not come on when I select AC. I did some cursory checks of fuses and relays F3 and F4 - but nothing obvious. Does anyone have a wiring diagram that could be faxed or Emailed? Or, a description of the circuit path would be better that nothing. Thanks in Advance!!
Chuck Bologna
1998.5 SE Sport MT
Dude, my car started doing this jsut this spring! I had cold air last year, and now, when I turn on the AC, I too do not hear the thing go on and the engine doesn't lose any power! And no cold air...
I'll be checking those relays you're talking about this afternoon when I get home.
:rolleyes:
Eric B.
Ottawa, ON, Canada
98 Mystique V6 5spd. Toreador Red
Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit
http://photos.yahoo.com/LBuzzer/
Low pressure a/c switch and/or low R134A pressure.......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
And that translated into english means what ??
laugh laugh
i have that problem... what should I do ??
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
If thats your problem, that means you have a leak somewhere and most of your refrigerant (R-134a) has probably leaked out. You need to find a reliable A/C shop (this can be tricky), and have them find the leak and repair it, and then recharge the system for you. Unfortunately A/C work tends to be kind of hard on your wallet, but if you find a place that does it right, then you won't have to worry about it for a while. Good luck.
And, since you mentioned the fan, the radiator fan kicks to high speed when the refrigerant pressure rises above a certain level. Without the compressor running, you won't get the pressure to switch on the high-speed fan. (Without refrigerant, you sure won't get the pressure either! laugh Sorry, couldn't resist...)
Garrick
Garrick
Silver E0, #3895 of 6535, built 10/2/97
She's stock. Why mess with a good thing? laugh
H
H
Welcome onboard.
Low refrigerant most probable cause. Take it in for leak check and recharge.
This current thread of another member's non-Contour might be worth the read time.
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=3;t=008458
stock CD on LS, cass on LX
4 wheel discs on LX only
you can get recharge kits at Wal-mart for about $30. I had cold air in the spring then it went away. I could hear the system cycling very fast when the Ac was on. The kit come with a hose, valve, pressure guage and a can of R-134A with oil and sealant in it. It imediately brought very cold air back right after the R-134A was put in. It is still cold but not quite as cold so I may still have a leak. Extra cans of R-134A were only $10, all were premixed with oil and sealant
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side
Father - 1995 Contour SE Duratec 5-spd
Mother - 1999 Contour SE Sport Duratec 5-spd
My CEG Registry
My Car
My Home Page
Any time you disconnect the battery, it takes a while for the computer to reset things. This should be the situation with the air conditioning. It took mine most of the 25 mile drive home to start blowing cool, but it did work.
Hey AC guys... i just disconnected my battery yesterday to do some work and today I didn't have ANY AC... I posted this and someone was trying to help me...
Is that computer resetting really the cause for my AC not working ?? I just need to know if that theory above is on the right track... confused confused
Thanks
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
H
H
BBorges:
Only if your Contour is a 2001 model and you have replaced OEM with a HAL computer, could it explain your problem. smile
The right track might be to review the "some work" you performed, and any fuses that might have blown.
