Posts: 13 |
I'm hoping someone knows of an easy fix for this because my mechanic didn't. My airbag light flashes, my horn doesn't work, and my steering waheel cruise control doesnt work either. All the fuses check out fine. thanks.
I'm a high school student with little to no money. I have a 98 Contour SE w/ 2.5L 24v V6 w/ 100k miles. I'd like to make some cheap performance upgrades <$1000 or so. I only spent 4k on the car. Mainly, I HATE Honda Civics and I want to blow them away. I usually can anyways! Any suggestions please e-mail me. devonb_37@hotmail.com
Alpine 240W CD receiver 4 Pioneer 6x8 3-ways. Yokohama Sport tires
Posts: 108 |
which fuses did u check the ones under the dash or the ones under the hood if it was the one under the dash check the fuses under the hood
1998 Toreador Red Svt #3486 0f 6535,fader window tint,JVC El Kameleon KD-LX100,JSP touring wing,resonater removed,cleared corners,door dings removed,omp strut tower brace
Posts: 13 |
Unfortunately, I checked both sets, but in the manual, the only thing related to the steering wheel is under the dash.
Posts: 5,805 |
The 'ribbon' cable behind the air bag/steering wheel appears to be broken....
Posts: 46 |
I Will lay money on it that it is your clockspring behing the horn pad.. I have seen at least 30 Contours come into my old dealership when I was writing service.. They all have the same symptoms..
John 1996 Ford Contour 2.0 Liter Turbo 5spd/ Pioneer 6.5" Television / DEH8000 CD Player/ Darkened Tail Lights/Shaved Emblems/ 17" Ultra Nocturno Rims 205/40-17's/ Custom Painted Cowl,Wipers, And Mirror Mounts/ Shaved Front Tag Holes And Window Squirters/ High Flow Catalytic Converter/Ford 9mm Spark Plug Wires/ Custom Exhaust Catalytic Back/Hyper White Lights/ Superchip/K&N Air Filter/Shortened Fubo Antenna/Billet Rear Antenna/ BNMotorsports White Face Gauge W/ Red Numerics And Matching HVAC Panel/H&R Coil Over Springs.
Posts: 587 |
Clockspring.. AGREED... behind horn pad.. easy fix.... I concur Ray
Posts: 13 |
your clockspring behing the horn pad any precautions i should keep in mind so as not to discharge my airbag? or is disconnecting the battery enough? thanks
Posts: 6 |
badass is right have to beleive clockspring
Posts: 1,040 |
Airbag has back-up power, wait at least a minute after battery disconnection before commencing work.
Posts: 46 |
Just disconnecting the battery is all that you need to do.. But wait around 2-3 Minutes becauseI have seen them go off on technicians and $700.00's is a big chunk to eat... Be careful..
