Both mounting tabs on the right headlight were cracked, so I figure it was time to replace the the nasty looking originals with new ones.
Eshopped around and found 'em for $114 a side - significant saving over the OE cost.
Got 'em today. They shipped complete with new bulbs installed, maybe not a bad deal. Marked with DOT designation, made in Taiwan.
Installed right side. Fit not PERFECT, but OK.
Installed left side. Fit could be better.
Adjusted right side, horizontal and vertical. OK
Adjusted left side, no horizontal movement.
Removed left, inspected adjusting mechanism and found plastic part that pushes/pulls adjusting lever was stripped.
Took apart original to transfer parts and found that the OE housing has a bronze bushing, not plastic as the follower on the adjusting mechanism.
Swapped parts, reinstalled left side and adjusted.
Bottom line - New lamps are a MASSIVE improvement, clear/clean lenses make a big difference in light transmission. BUT, if I had to do it over again, I'd spring for the extra $$ for OE parts.
AL
Red '98 SVT E0 3098/6535 DMD other stuff and a Bullitt fuel door
my mountung tabs were cracked as well, i just took what was left of them and drilled a whole in them then screwed a metal tab into the plastic, and mounted them up, it has worked for 2 years now
1994 Volvo 850 Turbo 1992 Bronco Eddie Bauer 5.8 E4OD 1998 Contour GL 2.5 CD4E 2001 Montero Sport Limited 3.5 Auto 2002 IS300 3.0 Auto See My Cars
I have the MM quad projectors and they have the "repops" and they too don't fit right but thats ok, Milan did a great job adjusting them. When its a custom made part you gotta expect that sort of thing and like I said before, the projector/HID set up is AMAZING Thanks again Milan
