I've been going thru some cel problems with my 97 contour 4cyl. One of the things the mechanic mentioned (not a ford dealer), was that a bad gas cap (this is tested in Mass as part of emmissions test) could cause your problem. Also was mentioned that if you gas up with car running, it can cause the cel to light up sometimes?
