Posts: 21,653 |
Originally posted by ZetecRacing: the 2100+ (1.73ghz) was running at inbetween a 2200+ and a 2400+ speed of 1.9ghz
so just .2ghz more burned it up? Did you get a bigger fan/heat sink or no?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
Originally posted by Kremithefrog: Originally posted by ZetecRacing: the 2100+ (1.73ghz) was running at inbetween a 2200+ and a 2400+ speed of 1.9ghz
on the 2100+ I was using a thremaltake VOlcano 7+ which is rated to support up to a 2800+
the 1800+ I have a Volcano 9 with a differnt fan on it the one that came on the volcano 9 was a 74cfm thermaltake fan I replaced it with a 80mm Vantec tornado which pushes 84.1cfm that heatsink with the original fan was rated up to a 3000+ now I have a thermalright SLK900U with a 92mm vantec tornado rated for 119cfm.
and with the two that burned up none of the went above what AMD states as the max working temps for the cores. my 1700+ on a hot day will hit up to 140F where the core is supose to be able to handle 190F before it would fail.
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 21,653 |
So unless I can keep it really cool, I just need to forget overclocking it?
98.5 SVT
Posts: 3,465 |
basicly.... and being that you have an older thunderbird core they tend to run hotter than the Tbred's or the Bartons which are the two current cores.
aka ZetecRacing
Posts: 200 |
without having to suck wang how do you get a company to replace a component which you have abused?
BTW If you can build a water cooling system they really make a difference, I made a real ghetto unit last year, it involved an old p3 heatsink drilled out and sealed up with an arcrylic top (ooh the luxury) for the waterblock, a cheap submergable pump and a bubba keg as a cistern, some 3/8 hosing, 3/8 barbs wire ties and a tube of plumbers goop and you got yourself a hero's water cooling system. Cost me next to nothing, the beer was the expensive part.
Posts: 1,957 |
carefull with amd's tho. Make sure that you connect the fans properly and none of the wires are loose. if the fan fails or is not on right, say bye bye.
NEED AN SVT REAR BUMPER!!! pm me
Posts: 200 |
on the topic of oc'ing whats the fastest clock gains anyone has made here, over 600mhz from my 2 gig p4....anything after that and it poops out
Posts: 637 |
im going to try and oc my 3000+ using my vapochill.. wanna see how much over 2.167 ghz i can get....
Posts: 3,465 |
Originally posted by blitzkrieg53: on the topic of oc'ing whats the fastest clock gains anyone has made here, over 600mhz from my 2 gig p4....anything after that and it poops out
well right now I am 790mhz over the stock speed... we shall see what I can do with my replacement 2100+
ooh and that's on good old LOUD air cooling too no water or any other extreme cooling system.
aka ZetecRacing
Posts: 3,465 |
Originally posted by WannaBe-SVT: im going to try and oc my 3000+ using my vapochill.. wanna see how much over 2.167 ghz i can get....
maybe 2.5 or 2.6ghz if your lucky.
aka ZetecRacing
