Posts: 165 |
Ok, now that I have driven the 'tour, I think I have discovered that the syncros for 2nd and 3rd are bad. 1. How long can I drive with the tranny in this condition? Do I need to watch my RPM's when shifting? 2. How much does it cost to ship a tranny and what is the best method? 3. What should I do with the tranny out? I would like clutch, flywheel and LSD, but do I really need the LSD? My only mods are an UDP and Cam Gears. Depending on the cost of this tranny thing, probably not too much else for a year or so. I would like to have the LSD for the snow, but am open (no pun intended) to not having it at the moment. 4. How long will it take to get everything done (shipping to Terry Haines vs. local shop and ordering parts in)? Thanks
Contour--It will make a master mechanic out of you!
95 LX MTX Bolt-ons
95 Neon SOHC ATX
77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
Posts: 165 |
95 LX MTX Bolt-ons
95 Neon SOHC ATX
Posts: 1,616 |
Originally posted by Oeneus: Anyone?
*bump*
Dude hold on..there are some tranny experts on here..they'll answer all your Qs in due time...
Posts: 283 |
I'm no expert but here are my opinions:
1 - a) You can likely continue to drive it for quite awhile but you may be costing yourself more in repairs. b) Yes, try to match RPM, shift smoothly and not under significant load. This will reduce the wear.
2 - a)& b) Can't recall the figures but if you call TH he can give you an idea and point you in the right direction for shipping and what to put the tranny into.
3 - While the tranny is out you should do all you can squeeze into your budget. It will never be less expensive because the major expense (usually) is pulling the tranny and putting it back in.
My understanding, from others that know these vehicles well is that an SVT clutch is quite adequite for most lightly to moderately modded 2.5L's. The flywheel is nice, you do notice the lighter weight.
You don't need an LSD, it's really a matter of what you want. A Quaife or Torsen will help any FWD get its power down. People have said that they put one in prior to doing upgrades in anticipation of needing it later and they were amazed at how much difference it made to a stocker.
4 - Depends on what you endup deciding to do, but there may not be much difference. TH will likely have most of what you need right away. Another shop may need to order parts. Either way you've got shipping time involved. 1-3 days shipping and 1-3 days tranny work if there isn't a wait list.
BTW, don't forget to do the Focus shift tower upgrade while you're at it.
Regards, Alan
03 Volvo S60 2.5T AWD
98 Mystique 2.5 MTX
99 SVT - Inheriting Lil Monster's parts
98 SVT - Lil Monster (RIP) 183.7 whp
Quaife/Fidanza/UR UD Clutch
AFE/MSDS/SHO-Y/Bassani/MagnaCore
GC/Koni/22mmR/EndLinks/ES/
KVR Slotted/1144's/SS Lines/MASItaly
Posts: 463 |
You can drive a tranny with bad on no syncros as long as you learn to double clutch. That is.. when you go to shift to the non-syncro gear press in the clutch, shift to natural, release the clutch, then press the clutch and shift into gear. Just like a trucker.
I drove my old mustang like this while waiting three weeks for Ford to get the 2nd speed hub inserts (part of the syncro).
jeff
have you fixed your ford lately?
Posts: 1,881 |
Shipping is around $60-70 and my tranny shop used UPS and I think Terry Haines uses Airborne Express. You need to crate it up for shipping.
1998 T-Red SVT #957
Born 5/14/1997
Posts: 165 |
Originally posted by mcgainer: Dude hold on..there are some tranny experts on here..they'll answer all your Qs in due time...
What do I want..... Answers! When do I want them... NOW!
Thanks for the responses! I guess I will just have to tighten my belt and do it. If anyone else has opinions or help, bring it on.
95 LX MTX Bolt-ons
95 Neon SOHC ATX
