Page 2 of 2 1 2
#701934 07/29/03 02:22 AM
Q
Q
Where do you find this stuff at? What exactly should I be looking for?
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels 1/4 mile - 15.201@89.4mph
#701935 07/29/03 02:30 AM
here
make sure you seal off the back of the mount(s) very very well first. 80 Shore A Durameter
a D*CK SLAP IN THE FACE IS ALL I GET FOR STICKING MY NECK OUT FOR A FORD... PLEASE DELETE MY ACCOUNT!
#701936 07/29/03 02:39 AM
what exactly does it do?
#701937 07/29/03 04:51 AM
Go to mcmaster.com
Type in this part number:
8644k18
not 80...but 94A!!! shore urethane casting compound
NOT IN A TUBE...this comes in a can with a primer bottle
This way it is a liquid and can sneak into every motor mount (Roll restricor) nook and cranny.
Its the stiffest stuff I could find, and its crazy stiff.
I was also told to use window weld or ESSEX which is what most OEM cars use for windows.
-Either one should be stiff...but for those who want the stiffest, this should do it. Also for those who dont know, its urethane you put in your motor mounts to firm up the engine movement/shifting/ etc.
#701938 07/29/03 11:43 AM
how many of thoes do i need? i plan on doing all the engine/tranny mounts, and all the bushings on the subframe etc
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#701939 07/29/03 08:16 PM
dang how do you upload pics...?nevermind i found a way
I would get an extra bottle...one bottle could do the front/rear just about
pic of insanity mount...its crazy stiff...hope you guys put it to good use.
http://www.fastcougar.com/forums/attachments/MVC-073F.JPG
#701940 07/29/03 09:36 PM
hmmmm - was this after you discovered that gummy bears were not stiff enough for motor mount inserts?
97 Contour SE MTX K&N 3530, UR UDP, 19# Injectors, mystery mod, FMS wires, Fordchip.com chip, SVT: TB, Flywheel, clutch, exhaust 04 Grand Caravan SXT
#701941 07/30/03 12:10 AM
I ATE THE GUMMY BEAR....hes done
I used some stiff urethane and found it to be a great improvement over stock...yet this new set of mounts will go on very soon.
#701942 08/06/03 02:28 AM
New mount installed....wow...nvh is outta control...my steering wheel buzzes left and right..and the cabin..WOW
and the car is ALOT louder...kinda like this cougar round town with SOLID METAL motor mounts and MSDS headers with a high flow exhaust etc
The car makes all kinds of weird noises now
Page 2 of 2 1 2
