#62065 05/31/02 03:03 PM
My alternator went out and a friend is changing it at his shop. Well, he's not done yet and he already said he'll never work on another SVT. Has anybody changed one out before? How hard is it really? Any input would be very appreciated.
'98.5 silver SVT, #6226 of 6535,
24mm AAM "aussiebar", KKM intake, custom y-pipe w/ high flow cat,
custom cat-back w/ Magnaflow race series mufflers w/ 4" tips, Bosch
+4s, FMS 9mm blue wires, IAT mod, Bullit fuel door, 35% tint all
around, APC clear sidemarkers, PIAA 510 driving lights, Cuzo
headlights, "carbon" sail panels, chopped shifter w/ Richbrook knob,
OBX pedal pads, "Bluepoint" Key Largo HU, Pioneer TS-A6955 6x9 3-way speakers in the doors, Precision Power PPI2240 amp, Xtant X410 10" sub in bandpass enclosure.
#62066 05/31/02 05:59 PM
H
H
Worst of any car I've ever owned in 40 years. Instead of 1 hour job for alt at top of motor (normal cars) it's many hours since alt is buried under exhaust manifold next to firewall and has to be removed thru' wheel well. Requires removal of tie rod for access, although Ford states driveshaft should be removed.
If this is a freebie you owe your friend BIG TIME. smile
stock CD on LS, cass on LX
4 wheel discs on LX only
#62067 05/31/02 07:13 PM
9
9
My "How-to" on changing an alternator... I have done it twice on my car now. Yes, it is about a 3-4 hour job for the do it yourself'er.
- Take the passanger's side wheel off
- Remove the two splash guards that are around
the driveshaft
- Disconnect the tie rod only
- Disconnect the 3 wires that go to the alternator
- remove bottom two bolts (Unbolt the black
bracket from the alternator, not the block)
- To get to the top bolt, I ran a long extension
from over near the driver's side wheel, with a
swivel type socket on the end of it. It was
VERY tight, so use high quality/strength tools
- Once all 3 bolts are out, the alternator is
still wedged quite hard in the brackets, so you
need to get a good grip on it and pull it out
of the bracket. It took alot of my body weight
on it to get it out, and I am a big guy, so
again, if its not on a lift this could be quite
challenging
- After a few bashed knuckles the alternator
should be out, and with a little finessing, you
should be able to squeeze it out with out
touching the drive shaft.
- As for replacing the brushes and regulator, I
took mine to a shop and had them replace the
brushes (of which 1 brush was off the spring)
They did not have my regulator in stock, so I
risked just changing the brushes (which did NOT
solve my problem ! To change out the
brushes, just unscrew the four screws, and take
them out carefully, so you don't loose a brush
in the alternator.
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
