This is my question. Whe call my Ford dealer to got the system to disable the air bag system.
You asking why? Because my girlfriend is a small person... Here in Quebec, whe need a certificate from the government to disable the air bag by the dealer. And whe got the certificate.
But the "switch" to disable the air bag is no more available for my car (Contour 1995 GL 4cyl 2L)
BUT, the dealer tell me to remove the fuse of the air bag. But the light is always on in the dash.
I DON'T want to cut any wire, but i'm asking if there is a easy solution to just remove the light itself?
Where I can find easy diagram of the wire in the dash to remove the good light or cut the good wire (if no other solution exist)
The problem is my girlfriend she in a "group" of people that she need to advance the seat at the maximum, abd she have the steering wheel in the chest, and if the air bag open, she can be killed (this is no joke). From the government, a person must be at a distance of 25cm from the middle of the chest to the steering wheel... below that is too dangerous. My girlfriend is at 9cm...
Thanks!
put tape over it.
Tony Datsenko
O
O
itty bitty thing isn't she?
I went with a girl who was 5ft nothing. She was sweet. Crazy too lol
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003 94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons. 02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
Come on... put tape it'a not a professional job... it's a cheap job...
Then I would just pull the dash and remove the bulb.
1998 T-Red SVT #957 Born 5/14/1997
Tell a Ford dealer you want to buy the air bag simulator.(there isn't much to it so it shouldn't cost much) Tell them you want it for diagnostics because you are getting a passanger airbag code. If they can or will sell you the simulator all you have to do is unplug the airbag and plug in the simulator. It is a small pencil shaped tool that makes the restraint control module think that there's a good airbag there and you could just leave it behind your glove box and if you ever dump that girl and find a BIG one you could unplug the simulator and plug the airbag back in.
Remove the dash? Ok, but where I can find the diagram to remove my dash? Does is very complicated?
But if I can have a diagram of my dash and how to remove?
If you remove the light the air bag module will forever beep at you until you replace the light.
redcontour.20megsfree.com/photo.html 98 T-Red SE Sport ATX ST200s Slightly Lowered Catless Y-Pipe Resonator Removed Clear Front Lenses Side Markers SVT Seats
Beeping? My air bag system don't beep or anything like that...
take the light out.
