#62008 05/30/02 07:37 PM
Seamore Offline OP
My 95 Se Duratech MTX has developed a problem that is really getting me pi$$ed off. When the car is warm (ie. run into a store for something quick and come back out) it starts fine, but makes a weird humming noise and refuses to idol(sp?), the tach will drop to all the way down and it will stall, giving it more gas will not help. [It only does this when the car is warmed up, no problems or sounds on cold start up.] It will do this several times in a row and then it will eventually start and run fine. In case it helps the car has 110k. Any suggestions would be great!!
95 Teal Se 5 spd,duratech, loaded(except moonroof) no mods.
#62009 05/30/02 08:15 PM
The first thing that comes to my mind after reading your post is that there may be a vapor lock in your fuel system.
Someone more skilled to answer your question will reply soon enough but until then here is my 2c worth.....
Check fuel pump opperation and see if your gas lines are holding a pressure.
My guess is that you have little or no pressure in the gas lines and the engine is starving for fuel. Also replace the fuel filter and see if that helps any.
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#62010 05/30/02 10:12 PM
Seamore Offline OP
If it was a fuel pressure problem wouldn't it do it more than when trying to start it when warm?? And what is the aweful humming noise associated with it?? I don't know about these newer cars, but we had a 80 Sunbird that when it vapor locked it would just shut down in traffic when she felt like it mad ! Beauty drives fine in all weather and traffic the only problem is it won't restart and idol when warm. So no fast trips into sheetz for a pepsi on a hot day!!! :rolleyes:
