Posts: 76 |
Joe
Red '95 Contour GL
Posts: 2,446 |
are the rca's ran with the power wires, that could be the cause of the buzzing
Posts: 1,092 |
Did you hook up the turn-on lead?
The buzzing is most likely caused by a bad ground or running the patch cables too close to the power wire. Also, turn your gain down.
1999 Ford Contour SVT #900/2760 (SOLD)
2005 Mazda 6s
2003.5 Mazdaspeed Protege
1998 Ford Ranger 4x4
Posts: 4,714 |
Joe, I can take a look at it tomorrow, if you'd like. I get home from work at about 5:30. PM me your address and I'll stop by about about 6 or so.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 76 |
Originally posted by FLCEGkid: are the rca's ran with the power wires, that could be the cause of the buzzing
yep i ran em both right next to each other under the molding along the bottom of my car
Joe
Red '95 Contour GL
Posts: 76 |
everything is hooked up right, i have no idea why it wont work, only thing i can think of is maybe a bad power cable but it looks fine to me
Joe
Red '95 Contour GL
Posts: 76 |
Originally posted by hetfield: Joe, I can take a look at it tomorrow, if you'd like. I get home from work at about 5:30. PM me your address and I'll stop by about about 6 or so.
where do you work/live? thanks but i have work tomorrow-thursday 1:30-9 each day..I'm off Friday and Saturday if you'd be willing to take a look at it then
Joe
Red '95 Contour GL
Posts: 1,092 |
Originally posted by xcigamxkcalbx: Originally posted by cthomp21: Did you hook up the turn-on lead?
Yes, but did you hook up a remote turn-on lead? You've made no mention of it when discussing your cables. The amp needs the following:
1 - unswitched power source from battery (your 8 GA cable) 2 - ground (GA should match power cable 3 - remote turn-on lead (switched power source from head unit, tells the amp when to turn on) 4 - signal (your patch cables) 5 - connection to speakers that are being amplified
2005 Mazda 6s
Posts: 76 |
I was callin it the power lead wire  im dumb, lol. and it cant be the power cable because its brand new..the rca cable im usin is old and looks kinda cheap so im thinkin that could be the problem
Joe
Red '95 Contour GL
Posts: 76 |
Well I got it to work..Instead of having my subs hooked up to 'output' on the amp I hooked the subs up to the 'bridge' part of my amp. thanks for the replies
Joe
Red '95 Contour GL
