Posts: 34 |
The Haynes manual states that when replacing the timing belt for the first time that the tensioner spring and spring retaining pin must be installed. I bought the tensioner, tensioner spring but do I need the spring retaining pin that the manual says that I need? The spring retaining pin is a bolt that the spring is hooked on to.
I have searched the forum archives and gained a lot of useful information. But no mention of having to buy and install the spring retaining pin.
'96 Mystique GS 2.0L ATX
Posts: 6,910 |
the spring and the pin are used to tension the belt only and do not stay installed on the engine.
we did not use the pin on my car. the spring is suppose to be of a certain tension so it tensions the belt corectly.
we used a punch to put in the pin hole and hook the spring to. also this allowed use to pull on the spring a bit more, punch was smaller then the bolt hole, to make sure we tensioned the belt
- 95 Mystique LS - Zetec/5spd
Posts: 34 |
Thank for the quick answer.
Posts: 21,653 |
You can leave them on the engine if you want, they won't hurt a thing. PM me tom, if you need the part number for the pin.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 6,910 |
you are better off taking them off, they could come free and jam the belt up, that wouldn't be any good
Posts: 21,653 |
A tight spring and a threaded bolt aren't likely to come loose.
98.5 SVT
Posts: 9,442 |
Actually when I went to the Ford dealer the pin and spring were only listed for use on the pre-98's.
Posts: 21,653 |
Originally posted by bk4293: Actually when I went to the Ford dealer the pin and spring were only listed for use on the pre-98's.
yeah and so far everyone that posted owns a pre98 zetec.
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: Originally posted by bk4293: Actually when I went to the Ford dealer the pin and spring were only listed for use on the pre-98's.
I guess we don't need a pin or spring.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
