#693922 07/16/03 04:14 AM
would headers for a cougar fit a CSVT? it is the same motor, if so i found a set from weapon R that are about half the price of the ones from MSDS.
Also is their anyone else out there who makes headers for my car?
1999 silver frost contour SVT #1951 of 2760 born 4/20/99 81,000 kms side exit exhaust pulley's hood gadges SOLD
With half the quality to match.
Chris G. ~ 98 Mystique LS ATX
Ditto. From what I've readw hen they first came out. Junk.
Ryan Trollin!
to answer your question - yes. they'll fit.
but like the previous two replies, they're junk. stay away from 'em.
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
I believe the Weapon R's have the 3 bolt flange at the cat. Contours have 2. WR's really are crap anyways.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
the 2 or 3 bolt flange depends on what year Contour and what transmission you have. The following is off of ctamotorsports.com. All Cougars may have 3 bolts only.
NOTE: Please specify your transmission type/ year/ and either 2- or 3-bolt cat converter inlet flange when ordering. The 3-bolt converter flange is usually on all automatics. Most vehicles produced after Nov. '99 came with the 3 bolt style, and is most noticeable by the large flex connector just past the first flange. 2-bolt styles used a donut gasket without the flex joint.
THEY ARE NOT A BOLT ON!!!
They are a blatant (or very poor quality) copy of MSDS's 02+ Cougar headers & Y-pipe.
The EGR tube is in a different position as are the 3 O2 sensor bungs. Yes I said 3.
The rear O2 bung must be plugged and 2 others added in the normal spots.
The EGR tube requires a skilled welder to fix! Possibly changing to the new Cougar EGR tube would work, but then you may have to change the EGR as well??? Time & $$$
IIRC the 2 main O2's will fit without having to alter the harness.
BTW - they are made from very thin wall cheap stainless and I would not place their longevity very high. (fatigue cracks from heat cycling comes to mind!)
Thanks guys i guess i'll have to spend a little more money.......................
