#61788 05/28/02 12:58 PM
MrPc Offline OP
Went to start my car this morning, and it made a clicking sound, then it eventually started. When it did start there was some hesitation. My CEL is on, with a bank 1 sensor 1 problem, and running lean. Any input on the problem would be appreciated. Thanks.
98 SVT
Black w/ Midnight Blue
Stock Rims
Sparco Pedals
Removed Resonator
TH Fix
Superwhite Bulbs
B&M Shifter
K&N Filter
KVR Cross-drilled rotors (front)
KVR Pads (front/back)
Aeroquip Steel brake lines (front)
#4248 of 6535 built
15.574 @ 88.35mph
15.814 @ 86.62mph
#61789 05/28/02 01:09 PM
H
H
Well I'd start with checking and cleaning the battery terminals before I would consider a bad starter.
Useful side effect is the CEL light will go out, giving you time to think about oxygen sensor shopping.
stock CD on LS, cass on LX
4 wheel discs on LX only
#61790 05/28/02 10:06 PM
MrPc Offline OP
If it is the starter, how much could that run?
98 SVT
Stock Rims
Sparco Pedals
Removed Resonator
TH Fix
Superwhite Bulbs
B&M Shifter
K&N Filter
#4248 of 6535 built
15.574 @ 88.35mph
15.814 @ 86.62mph
#61791 05/31/02 11:37 AM
MrPc Offline OP
Well I found out it is the starter that needs to be replaced. Any tips on replacing it?
98 SVT
Stock Rims
Sparco Pedals
Removed Resonator
TH Fix
Superwhite Bulbs
B&M Shifter
K&N Filter
#4248 of 6535 built
15.574 @ 88.35mph
15.814 @ 86.62mph
#61792 05/31/02 12:23 PM
I've got a good used starter for sale if you're interested. I'd take $75 for it plus a little shipping. New one from ford is over $120. Replacing it isn't too bad of a job. It sits directly on top of the transmission housing under the throttle body area on your intake. Should take an hour +/- to change out if you are mechanically inclined.
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#61793 05/31/02 06:27 PM
MrPc Offline OP
Thanks for the starter, but I got a discount through a friend for one. Actually that same friend is going to do the job for me, he's a mechanic at a pontiac dealer so I guess it shouldn't take long.
98 SVT
Stock Rims
Sparco Pedals
Removed Resonator
TH Fix
Superwhite Bulbs
B&M Shifter
K&N Filter
#4248 of 6535 built
15.574 @ 88.35mph
15.814 @ 86.62mph
