Posts: 148 |
Went to start my car this morning, and it made a clicking sound, then it eventually started. When it did start there was some hesitation. My CEL is on, with a bank 1 sensor 1 problem, and running lean. Any input on the problem would be appreciated. Thanks.
98 SVT Black w/ Midnight Blue Stock Rims Sparco Pedals Removed Resonator TH Fix Superwhite Bulbs B&M Shifter K&N Filter KVR Cross-drilled rotors (front) KVR Pads (front/back) Aeroquip Steel brake lines (front) #4248 of 6535 built 15.574 @ 88.35mph 15.814 @ 86.62mph
Posts: 1,040 |
Well I'd start with checking and cleaning the battery terminals before I would consider a bad starter. Useful side effect is the CEL light will go out, giving you time to think about oxygen sensor shopping.
Posts: 148 |
If it is the starter, how much could that run?
Posts: 148 |
Well I found out it is the starter that needs to be replaced. Any tips on replacing it?
Posts: 1,611 |
I've got a good used starter for sale if you're interested. I'd take $75 for it plus a little shipping. New one from ford is over $120. Replacing it isn't too bad of a job. It sits directly on top of the transmission housing under the throttle body area on your intake. Should take an hour +/- to change out if you are mechanically inclined.
Rick
The first Blown 3 Liter! "Drive it till the wheels fall off" -my personal motto!!!! 98.5 T-Red SVT #6180 Many Mods Buckshot77@aol.com Owner of 00 #1611 Silver Totalled on 10/7/01 SVT Parts for Sale
Posts: 148 |
Thanks for the starter, but I got a discount through a friend for one. Actually that same friend is going to do the job for me, he's a mechanic at a pontiac dealer so I guess it shouldn't take long.
