I just bought a used superchip (code:PEW4) for my 99 CSVT and I am sending to Kurtz Kustom to get it reflashed (my code:SFG2) Should I have them do anything special(secondaries open earlier, remove speed limiter, etc.) or just let them flash it with the standard code. In the normal reflash, do they usually remove the rev and speed limiter, or do I need to ask them specifically. Thanks for all of the info in advance.
- Andrew
1999 SVT TRed/Tan: B-Day 1/28/99 #1034/2760 Sony ABP HU, Kenwood 800w Amp, XPLOD ES 800w Amp, Lightning Audio 1 Frd. Cap w/ Dig Readout, 2 12" JL W3's, Pioneer 6x8, K&N RU-3530, Superchip, SVT Sill Plates, Grill Mod, Ding guard-less, B&M Short throw
Q
Q
Just for your information SVT's have no speed limiter. They are drag limited at 143.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels 1/4 mile - 15.201@89.4mph
What is the difference?
It means the engine dosent have enough power to overcome wind resistance past 143 mph. Might be lower depending on maintenance, tire wear, etc.
Some people with modified cars claim to have hit 149-150, though I dont think any of those claims have been verified.
the more you ask the more you learn, thanks.
Nah...I don't think anybody has shown gains from doing such.
As far as the standard code goes...well, what mods to you have? What mods do you plan on doing? Give us some more info, and we'll give you some more back.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
F
F
SMELLY the SFG2 superchip code works very well on the SVT, it's the code I have and Kurtz does a good job burning them.
Get the standard code, it will more than suffice unless you have FI or different injectors..
maybe for headers or MAF
The SFG2 code will raise your REV limiter to 7500-7600 RPMS..
your secondaries will open up about 4-500 rpms earlier than what you see them doing now..
I see you sent me a PM on the "knock sensor mod"
you have to realize if you do this you do it at your own RISK!
Knock sensors on the SVT are screwed into the rear block,
if it detecs "knock" it will signal the computer and the computer will RETARD timing = less power.
Knock sensors are good but sometimes TOO sensitive, sport compact car does this to inconsistent cars on the dyno.
Knock sensors if too sensitive can and will detect other noises from the engine and deem them as harmful even though their normal and thus retard timing.
You must have a healthy engine or this isn't a mod I recommend.. and you better know your A/F is pretty good.
you can remove the knock sensor from block.. wrapp in a small towel of sorts and zip tie it somewhere safely. You must leave the sensor plugged or the computer will probably get a CEL and the computer will retard timing all across the rev band. Also, you must run a GROUND from the sensor itself to a good ground connection. In stock mode the block grounds the sensor.
The right way to do it is to run a 500,000 ohm resister from the (i believe from the left terminal) of the plug itself.
it doesn't add power it just makes your car more consistent..
my car was very inconsistent..one day it felt like a 1.6 vtec turd si and another like a v8 beast..
I couldn't figure it out until I read up on the timing issue and what affects it..
anyways my car runs great everyday now..
oh one more thing.. my friend with the SE v6 contour swore that every car comes with knock sensors..
they DON't
his SE v6 didn't!
Eric
Keyser desensitized my knocksensor via my diablo chip. IMO, it's much easier than fuggin with the actual sensor.
they DON't
his SE v6 didn't!
Eric
does the superchip really do this ? thats the first good thing i have heard about the superchip. if so this is my next performance mod. since i have other mods such as intake and y-pipe dont they program it to the mods i have ?
FORSALE - 17" FSVT Wheels, TRubendz catback w/magnaflow muffler PM ME 02 celica GT-S 6-spd w/ TRD bodykit Greddy evoII exhaust, DC sports header Injen Short ram intake, TWM short throw shifter, 18"centerline storm wheels, Tein basic coilovers
