HX65 DTC P1451: CHECK VPWR VOLTAGE TO CV SOLENOID
Diagnostic Trouble Code (DTC) P1451 indicates that Self-Test has detected a canister vent (CV) solenoid circuit failure.
Possible causes:
VPRW circuit open.
CV circuit open.
CV circuit shorted to PWR GND.
CV circuit shorted to PWR.
Damaged CV solenoid.
Damaged PCM.
1) Key off. Disconnect CV solenoid.
2) Key on, engine off.
3) Measure VPWR circuit voltage at CV solenoid harness connector. Key off. Was voltage greater than 10.5 volts?
No - REPAIR open circuit.
Yes - HX66 CHECK CV SOLENOID RESISTANCE
Measure CV solenoid resistance.
Is resistance between 48 and 65 ohms?
No - REPLACE damaged CV solenoid.
Yes - HX67 CHECK FOR OPEN CV CIRCUIT BETWEEN PCM AND CV SOLENOID
