#689540 07/12/03 03:59 PM
O
Oeneus Offline OP
O
Ok, guys, real quick,
In what hose do I put the TEE in to flush the radiator? I'm thinking it is supposed to be the hose that comes out the back of the thermostat, but is there an easier one to get to, or does it work ok? And is there a trick to getting the drain plug on the radiator out? If I try to use a screw driver, I can't turn it cause it is sitting on the frame.
Thanks
Contour--It will make a master mechanic out of you! 95 LX MTX Bolt-ons 95 Neon SOHC ATX 77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
#689541 07/12/03 04:09 PM
Forget the drain plug. I guess the intern who designed it
had a particularly bad day at Ford
Go under the car and follow the metal pipes coming out
from the rad on the right side. Find the joint where it
ends and continues in a rubber hose (about 10" back from
the rad). Pull the spring clip and pull them apart.
(It's much more obvious if you see it).
T.
#689542 07/12/03 04:32 PM
O
Oeneus Offline OP
O
T.
You're saying this is where I drain it, right? Then do I put the TEE bteween the fire wall, and the thermostat housing?
Thanks
#689543 07/21/03 05:19 AM
i am having the same ? where do i put the flush tee at
my friend told me right by the expanison tank but the box says to install at the heatercore inlet
96 Contour Gl (wifes new car 91 GVR4#1382 (the true sleeper 91 TSI AWD (project celluite AWD & 4WS what else do you want in a car
