Posts: 9,602 |
Originally posted by Antiramie: I stick with full synthetics only...
Isn't that an Oxymoron!!!
Castrol & Synthetic in the same sentence...
I personally use 6+ qts of Mobil 1 5W30 and a K&N Filter.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,714 |
Around here, Farm & Fleet has them for $8.99, and some Checkers (aka Kragen) too. Problem is no one ever has any in stock. I had to drive a half hour out of my way the other day to the next closest Farm & Fleet, and when I got there I cleared them out of their stock. I should be set for the next year
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 1,521 |
It's actually 2-stroke oil, but that doesn't matter, right?
Mobil-1 + Motorcraft filter for me.
Chris G.
~ 98 Mystique LS ATX
Posts: 846 |
Mobil 1 Full Synthetic 15-50 Racing Formula Oil K&N Gold (2010) Oil Filter 2 Quarts of Lucas Oil Additive
-Bishop
*Invisible Hero*
1999 SVT Contour/Amazon Green
Keep It Real.
Beware the fury of the silent man.
Posts: 7 |
ira's 2000 Mystique ATX w/Religious 3K oil changes I use the Mobile 1 filter and rotate the following oils FULL SYNTHETICS ONLY: Pensoil/Mobil 1/Havoline/Castrol/Valvoline 5W/30 in Summer 0W/30 in winter For some twisted reason I have this thought that different brands have different additive packages that could clean up deposites & contaminants left by the previous. I don't run my car hard so I think thermal protection in my case is even across the board.
Posts: 1,521 |
Originally posted by MySVTique: ira's 2000 Mystique ATX w/Religious 3K oil changes I use the Mobile 1 filter and rotate the following oils FULL SYNTHETICS ONLY: Pensoil/Mobil 1/Havoline/Castrol/Valvoline 5W/30 in Summer 0W/30 in winter For some twisted reason I have this thought that different brands have different additive packages that could clean up deposites & contaminants left by the previous. I don't run my car hard so I think thermal protection in my case is even across the board.
If you like variety, here's the lineup you should be rotating: Mobil 1/RedLine/Amsoil/Royal Purple. Ditch the rest...
Chris G.
Posts: 1,254 |
Royal Purple & NAPA Gold filter.
**FYI** the NAPA Gold and the K&N filter are the same. i have a guy who races trucks and he did all kinds of research to back this up too.....their identical filters!
Posts: 3,867 |
Originally posted by hetfield: The Motorcraft filters (which are rebranded Purolator filters) are also very good.
...but stick with Motorcraft, in this case. The filter and casing are the same, but the bypass valve on the Motorcraft is in a Ford-spec'd location, different than on the Purolator.
Me, I'm Mobil 1 5W-30 with Mobil 1 filter.
FWIW, the Mobil 1 and K&N Filters are both made by Champion. The Mobil 1 has higher burst strength, greater capacity, and better filtering efficiency than the K&N, but the K&N has a higher flow capacity--good for frequent trips to high rpm range. (i.e., it will keep filtering oil after the rev point where the Mobil 1 filter goes to bypass, but only so far.) Bottom line: Both are very good filters, with slightly different emphasis.
Function before fashion.
'96 Contour SE
Posts: 4,714 |
[Johnny Carson]I did not know that[/Johnny Carson] Very good info, thanks!
I think the universal advice, though is stay away from Fram!!!
Hooray Beer.
Pictures
Posts: 1,128 |
Originally posted by SVTDriver1: Mobil 1 Full Synthetic 15-50 Racing Formula Oil K&N Gold (2010) Oil Filter 2 Quarts of Lucas Oil Additive
-Bishop
same here but leave out the Lucas KRAP!
proven to actually work against oil over time.
eric
