Posts: 110 |
are there any shortcuts for the haynes manual way to take off the exhaust manifolds? i dont' want any dust getting into the cylinder walls when i optimize them..
I already have the ypipe off, and i'm going to clean the intakes. so its not much more work is it? (haynes manual says to take off the right side wheel??)
Black E0 SVT
Posts: 1,044 |
Some of the bolts are biatch to get to. Taking off the Rt. wheel will make some of bolts more accessible.
Posts: 70 |
wobble extensions also help a LOT. I took out the alt. bolts and slid it back too. Remember to disconnect batery!
98 Black SVT
Posts: 110 |
hrm, maybe this is a bigger job then i thought..
Black E0 SVT
Posts: 110 |
ok, i just finished taking the intakes off and cleaning them. and my ypipe is already off too, so i think i might as well take off my precats and clear em out. but how do i go about getting at them? the haynes manual doesn't say how to get at them, do i have to go from underneath? also i just moved the fuel rail w/ injectors out of the way when i took the LIM off, i don't know if that was right but i couldn't understand the how-to.
Black E0 SVT
Posts: 110 |
i can't get the injectors out either, i can turn them by hand but they don't come out and i dont' want to break them by using something to pry them out.. any suggestions?
Black E0 SVT
Posts: 1,746 |
Originally posted by mtxContour97SE: but how do i go about getting at them? the haynes manual doesn't say how to get at them, do i have to go from underneath?
yup.
Posts: 3,506 |
Originally posted by Jason43: Originally posted by mtxContour97SE: but how do i go about getting at them? the haynes manual doesn't say how to get at them, do i have to go from underneath?
yup.
Check Fastcourgar.com One of the guys on the NECO forums Has a how too done on how to get to them and take them off....All i got to say is i hope you ahve little hands and a lot of time.
Roz
Posts: 160 |
Originally posted by mtxContour97SE: i can't get the injectors out either, i can turn them by hand but they don't come out and i dont' want to break them by using something to pry them out.. any suggestions?
It's a lot easier if you disconnect the fuel lines and remove the fuel rail from the car to give you a little better "purchase" on grabbing the injectors. They are a bear to pull out but you just have to keep twisting and pulling until you get them loose (you will have sore hands and fingers by the time you're finished). You gotta get them out about 3/16" or so to release the nose o-ring from its bore. It took me several minutes, each, to get them disassembled. Prying on them is pretty much of a no-no since you could easily crack the plastic on the injector. Re-installing the oil-lubricated new ones in is a breeze, however.
'95 Contour SE, MTX, Champagne
'03 EB Expedition, Med Wedgewood Blue
Posts: 110 |
[quote=KurtD It's a lot easier if you disconnect the fuel lines and remove the fuel rail from the car to give you a little better "purchase" on grabbing the injectors. They are a bear to pull out but you just have to keep twisting and pulling until you get them loose (you will have sore hands and fingers by the time you're finished).
yeah my hands are sore haha, i just finished getting them out and those 'quick release' fuel lines were a pain also since the 'X' tool is junk.
should i clean the injectors? and if so how?
Black E0 SVT
