Posts: 55 |
I want to remove the orange reflectors in my headlights. is there any way possible to do this without taking the lens off of the headlight? I think it would look so much better without them.
Green '99 Contour SE Sport ATX -- wrecked
Silver '00 CSVT 3L hybrid
Silver '95 Thunderbird "3.8 V6" -- swapped 5.0 from wrecked mustang FREEBIE!!!
Posts: 2,446 |
Yes there is. Sorry to sound like the "search flamers" but search for the how-to, i cant exactly remembe it right of hand but i know its out there.
Posts: 202 |
there is a how-to somewhere that i followed. basically, you drill out the tabs that hold the reflector in, crunch it up inside the light, and pull out the pieces through the turn signal. then you seal up where you drilled and you're finished. now let me see if i can find that how-to......
#1000 of 2760
Money talks, it says good-bye!!!
19's are here...
Posts: 903 |
I have been looking for the how-to also, cant seem to find it.
Posts: 173 |
Posts: 55 |
Posts: 1,012 |
All that drilling isn't neccessary.....Just take off the light, remove the bulbs, and take a very long screwdriver with the end taped up heavily, and pop out the reflectors, then crunch them up. That is exaclty what I did, and it took about 5 minutes.
Posts: 103 |
i attempted that as well, those flaps are glued/melted on the headlight housing, they don't "just" pop-off... for some i guess it did. I had to drill... all in all about 45 minutes each lamp. Good Luck...
Jeff Silva
E0 Contour SVT Silver
-STEEDA PEDALS
-K&N Drop In
-Ford Racing Wires (w/Bosch +2's)
-Cleared Headlights
-Yokohama AVS ES100's
-Alpine CDA7893 w/MBQuartz
-EUROLITE 9006/893
Posts: 173 |
Originally posted by FreeProjectPat: All that drilling isn't neccessary.....Just take off the light, remove the bulbs, and take a very long screwdriver with the end taped up heavily, and pop out the reflectors, then crunch them up. That is exaclty what I did, and it took about 5 minutes.
That is a good way to scratch up the reflective coating inside your housing. It also sounds like you got a set that the reflectors were not molded in very well. Mine were in there, and there was no way just taking a screwdriver would have gotten them out. I would be most concerned about the scratches though.
Posts: 1,421 |
I wonder what the parking lights would look like after this. Any pics?
99 Black SVT -3L Hybrid w/.5mm overbore, Spec clutch/flywheel, MSDS, BAT intake, K&N open, 17'Konig Tantrums, DMD, Opt. TB & Y, Powerslots, Bassani w/ magnaflow res.
96 SE MTX- "The War Wagon"
"I'm in love with my car..."
-Queen
