#61368 05/22/02 06:01 AM
dwh Offline OP
When I start my car in the morning, after I first put it into gear (any gear), it almost, but not quite stalls. Sometimes it will even backfire? (not really, but that is the only way I can think to describe it--loading up the intake). I don't have the TH fix, and this engine only has 2500 miles on it. It ran really good, but lately I have become concerned. The gas milage has dropped from 28mpg to about 22mpg or less. After it runs for 5 minuts or so.... It is fine. Does anyone care to throw in a bench diagnostic from my description? I am clueless.
TIA
***edit*** And there are NO cels, so I can't pull a code. (I tried)
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
#61369 05/22/02 12:04 PM
IAC Valve.
Mine does the same thing. Just picked up the valve, only 94 bucks CDN from the dealer. Unfortunately, it looks like I'll have to pull the intake manifold off to replace it. ACK!
#61370 05/22/02 03:00 PM
dwh Offline OP
Kewl!
I hope that is all it is. It is very insidious.
#61371 05/22/02 03:32 PM
Check vacuum hoses after the MAF Adapter, could be loose, which causes loopey idling. . .
'98 Black SVT #651 of 6535
KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust.
Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17)
BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears)
Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps.
Hella Stage II HIDS from hids4less.com.
Recaro Sport Seats trimmed in supple black leather.
And Zymol wax to keep it squeaky clean.
