#684516 07/07/03 07:24 AM
Has any one ever replaced an o2 sensor in their car yet? i went to my dealer ship and i told them that i thought my o2 sensor might be out because i had a test done at autozone and they asked me if it was the left or right side and i was like huh. lol i thought it only had one. well i was just wondering on how much they cost i think he said something about 115 or some thing but thats not including on the labor or any thing. but well i was just wondering how hard it would be to change it if i would have bought it. i have a 2.5, v6, durtech so give me some feed back.
JokeR
Players club JVC Arcinal HU 2 12in punch he 600 watt punch amp 7 inch wide screen flip down PS2 in glove box
#684517 07/07/03 11:28 AM
1995 V6 has 2 O2 sensors.
1996+ V6 has 4 O2 sensors.
Sensors cost around $60-70 each.
If you search the boards, you will find plenty of posts on this topic.
#684518 07/07/03 02:13 PM
i have a 99 contour se and the engin light is on so i took it to autozone and he said that its my o2 sensor i think i will run up today because i have to set up an appoitment with my dealer to have an inspection and well a sparkplugs and stuff put in because i dont feel like messing with them
JokeR
#684519 07/07/03 02:20 PM
It is very likely that all you need is to clean your Throttle Body (TB). Search on this site to find out how easy it really is to do it yourself & save a bunch of money.
I also have a 99 SE with a V-6 & AutoZone told me to replace O2 sensors. They were full of it. Cleaned my TB & everything was cool.
Did they tell you what the code numbers were? Find out, then do a search for the P0402, or whatever number they give you & you'll lean a bunch about your car & how to maintain it yourself. Again, you'll save lots of money. We can even teach you easy ways to reset your CEL.
