DennyS Offline OP
Hi guys just made a search and didn't find anything on how to replace it. Just wondering if someone could give me a list of steps and tools needed to replace the serpentine belt on my zetec, it's a 96. Thanks
1996 Contour GL, Zetec, ATX, Midnight Blue Bellevue Ohio Mods --> Ford Racing 9mm Plug Wires so far
Here's the way I do it: Jam some blocks or other support under the oil pan to hold it up, then remove the top engine mount above the belt area. Get a half-inch socket wrench or breaker bar and insert it into the square hole on the tensioner. Push it up against the spring (you may want to extend the handle with a pipe) and the belt will loosen and you can pull it off. Repeat the same move to allow the new belt to be fitted on. You might need a second pair of hands for that.
DennyS Offline OP
Thanks Paul !
