#683757 07/06/03 01:22 PM
arble Offline OP
With the a/c on, the interior fills with a smell that's hard to describe but very annoying--musty rotten eggs, maybe? There also seems to be less cold air than before; I have to have it on Max AC with the fan turned up to make it cool. Yesterday I did a four-hour trip and I'm still feeling a bit dizzy (although if that's related to the smell I don't know). The evaporator drain lines aren't clogged (water drains out onto the ground) so I don't think it's a "mold in the ducts" problem. I replaced the cabin air filter 5000 miles ago, if that's relevant. Last fall the dealer had to add refrigerant but couldn't find a leak. Those are the facts; any idea what the trouble could be? Is this something my local Mobil station can handle, or do I need the dealer?
#683758 07/06/03 01:41 PM
I think disgusting smells from the a/c ARE usually "mold in the ducts". The fact that you have to run the a/c on
MAX which just recirculates the inside air only compounds the problem.
Both the Jeep and Mystique have had that smell, but usually it dissipates after a few minutes.
Maybe when you first startup, run the a/c on fresh air first, then max for awhile, then back to fresh...etc.
I'd have someone who knows a/c check the refrigerant again.
- Jim Our yardbirds: Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
