#61309 05/21/02 01:28 AM
Mike H Offline OP
I've got a '97 SE with, apparently, gremlins in the electrial systems.
Symptoms:
1. Randomly, when the key is removed from the ignition and the door is opened, the "lights are on" chime will sound even if the lights are off. This goes away as soon as I start the car.
2. My Ford-installed Ford-branded alarm system installed by (guess who, Ford!) will leave the parking lights on, randomly, again, when they pulse on the second time after it's armed. I can turn them off by disarming and re-arming the system.
Any ideas? Anyone with similar woes? Are the problems related? Can someone possibly get me a wiring diagram of some sort for the alarm system? I'm comfortable with electronics, and if it's just a faulty connection or blown resistor or something, I don't want to have to pay Ford to have the work done.
Mike in Houston
(V6 '97 SE)
"If at first you don't succeed, destroy all evidence that you tried."
#61310 05/21/02 02:18 AM
When this happens, with the key removed, push on the ignition lock cylinder and it should "pop" out. Mine does this as well from time to time. My lock cylinder doesn't always quite come out every time the key is removed.
The sound is the "key in ignition" chime mode, and as soon as you pop the cylinder out it will go away. Seems the switch to indicate the keys are in the ignition is triggered by the cylinder being in slightly (which happens when you insert the key and is supposed to come out when you remove it). The warning only happens when the keys are in the ignition, with the engine off, and the driver's door open.
