Are you sure that you fixed the vacuum line? I would try and properly fix the line first before looking anywhere else. A broken vacuum line can lead to all sorts of driveability issues.
For a short term fix, you can try buying a short length (3-4") of copper tubing that will fit the inside diameter of the vacuum tubing. Then use the copper tubing to "join" the two pieces of vacuum tube. Tighten the vacuum tubes on top of the copper tubing with hose clamps.
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
