N
N
I have a 95' V6 contour. It has been running bad only when it is cold. I push the gas to the floor and it just pops and backfires. Then once it starts to warm up(4 or 5 blocks down the road) it runs perfect. It seems to idle fine when cold just once I start to give it gas to move it starts to backfire. I changed the plugs and wires as someone told me to do. This has not solved the problem. Any other suggestions? I don't feel like replacing every sensor and part to find that it was not the problem. Any ideas?
1995 V6 ATX LX Contour
1993 V6 Ford Thunderbird Super Coupe : 14.371 @ 95.5mph with lots o' wheel spin!
Your problem sounds familar, I have a '95 Mystique 2.5 as well and have the same symptoms. I to have replaced the plugs and wires, the wires were replaced because one was grounding out on the motor. Could it be possible that the coil pack was damaged as a result of the faulty wire? The vehicle seems to run fine (with no missing or jerky hesitation) after a few minutes?? Any suggestions??
I had the same problem. I took it to ford and they had it for 4 days and they found a bad vacum line under the upper intake maifold. Check your vacum lines.
Pete
Have you "Cracked" your secondaries? This can lead to that problem during cold weather.
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
