#682249 07/03/03 07:24 PM
Leave it to Ford to put a maintenance item in an impossible place to get to. The stock manifolds are in the way, the egr tubes are in the way. I got the pcv hose of the valve but now I can't get to the valve
95 Contour Gl - the work beater - bought 6/15/03 88 S-10 Blazer - back up beater - owned since 89 97 Cobra Vert - my weekend toy - bought 12/01
#682250 07/03/03 07:30 PM
WRONG !!! Get for $17.00 the Chilton Ford Contour 1995-99 Repair Manual and will guide you step by step and it will be mad easy...no problems..
___________________________ '95 Contour GL 2.0L (170K) A/T
#682251 07/03/03 07:31 PM
I have the manual, sucks donkey nuts.
#682252 07/03/03 07:32 PM
fire will loose them a little bit..
#682253 07/03/03 07:37 PM
losen what I have the Haynes manual. It's not the manual, I just cant get a hand on the stupid thing to get it out. I know its the original one too, only 194,000 miles on her
#682254 07/04/03 02:29 AM
Hi....
Is this a Zetec engine? It is the most absolute engineering mess I have ever seen. They place a tork screw under the thermostat housing that one must remove to get the steel tube back enough to get the PCV valve out...You end having to dismantle far too much just to remove a simple PCV valve.
Another thing to check is the rubber tube in the back which connects to intake manifold area. I found my newly bought 98 Merc's being sucked flat and wasn't working hardly at all. PCV filter in air filter box must be clean in order to pass air to valve cover then through oil seprator to PCV valve and through steel pipe, rubber tube to intake....Could have been made so simple, but Ford did not care to do.....Even the rubber tube is special in the back with a sharp 90 degree bend and a $17 price tag, when you can find one at the dealer....?????????
Duane Koss / Blue Springs, MO
#682255 07/04/03 05:23 AM
Originally posted by dak507:
Hi....
Yup its a zetec engine. I took care of that stupid steel pipe. Nothing like an air grinder, cut it in half. So now I have a rubber hose connecting to the pcv valve. Next time it will be really easy, not having to unhook alot of unnecessary parts
#682256 08/22/03 03:04 AM
Hi....
Hi,
Do you have picture of this please..
