I tried to install a switch to run some LEDS and other Neon stuff but either way i did it i got sparks and blowin fuses. I used a switch hooked the power up to a fuse and the ground to a screw, but either way i connected it i had sparks, for instance if i put the power one on first when i put the ground on i go a ton of sparks and i tried it the other way also, but still sparks....IS there any other way to tap into a power source with out frying myself or the car???
Thanks
Alpha
