The ugly kink in the rear cylinder 180 deg bend on the MSDS Y-pipe was just too much for me to take.
So I flowed tested it on a Superflow bench, and modified it.
Flow #'s are cfm at 20" H20.
Configuration---------Base-------- Modified
Front Bank tube-------393----------393
Rear Bank tube--------326----------381
Flow delta (%)--------17%----------3%
The modification was to install a 2.0" stamped "donut" as shown. A simple fixture was used to ensure that it will fit on the car the same. Can't wait to try it! I'll try and flow test the stock Y-pipe once I remove it.
