#61236 05/20/02 05:28 AM
mhodzic Offline OP
Hi, I just picked up a 96 Contour SE 5speed. When I shift from 2-3 I hear a little gear grind. Does this mean that clutch is gone or my clutch is not engaged fully when all the way down. It also happend on 1-2 shift if you take it to higher rpm's. By the way do these cars have hydrulic clutch or cable(mechanical)? And how do you adjust these to make sure it is not the bad clutch, before I start ripping the trany off to replace the clutch?
thanks,
mhodzic
curent owner of 90 SHO and active member at
www.shoforum.com
#61237 05/20/02 10:15 AM
Clutch is hydraulic & self adjusting.If the clutch clears on first without any grind it sounds ok,can bleed it if you like but I'd change the trans fluid first,as its an older trans stick with Mercon III,if you have 'blocked' upshifts and/or noisy shifts the syncros could be worn....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#61238 05/20/02 01:39 PM
I had the same thing on my '00 SVT, 2-3 shift at Higher RPM'S (over 3k), bad 3rd gear, 3 & 4th gear synchro's. I would bring it back if you have any sort of 30 day 1,000mi type warranty.. Thank GOD I did.. it was 13.2 hours of labor plus parts(although Terry says it should take about 11 hours, but he knows what the hell he's doing laugh )
#61239 05/21/02 03:36 PM
mhodzic,
Had a similar problem with my '99 V6 on 1-2 upshift. I had it fixed under warranty and was told that the synchro had worn prematurely. They replaced the whole unit. Sounds like you may have a similar issue to what I had.
Regards,
Adam Strean
1999 Contour SE V6
#61240 05/21/02 04:57 PM
hope you have a warranty if its the syncros...$$$ frown
-neal
99 SVT...modified
96 GL....the beater
"I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
#61241 05/21/02 05:03 PM
-neal
like I said.. it was a 13.2 hour job for mine at the Ford dealer. mad
