Posts: 1,677 |
Hello, I drive a 1999 Ford Contour LX Zetec ATX. While driving today, with the air on, it suddenly turns off. I had it on Max-A/C with it on the 3rd out of 4th settings. It just suddenly turned off for no reason, I wasn't changing settings or anything. It works If and Only If I put it on High, the 4th setting out of 4, but not for any of the first 3 settings. Any ideas?
Posts: 759 |
Do a search next time. There are a BUNCH of threads on this...has to do with a faulty speed selector switch resistor. There is a TSB on it. Search for Blower Motor too
Posts: 1,677 |
I did do a search, I swear! I search in "all forums" for "Air conditioning" in "all posts", and I got no results. Thanks for your answer anyway, this was great info, you are the man!
Posts: 6 |
You problem is a blower motor resistor pack!!
these are located in the passenger side , in the left side of the ventilation motor of the A.C.
Posts: 667 |
Originally posted by jerseycat10: I did do a search, I swear! I search in "all forums" for "Air conditioning" in "all posts", and I got no results. Thanks for your answer anyway, this was great info, you are the man!
Well, you must have searched incorrectly, because I just did the same search for the past week and came up with 22 hits!
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 1,677 |
yeah, it was weird, I went back later to do the search, and it worked fine. I am having intermittent connections at work, so mayber that was what happened. At any rate, I just made an appointment tfor next Tuesday to have the safety recall performed. They said it would be free of charge, and that I could not pick up the resistor pack and install it myself because it is a safety recall and it is illegal to do that. I am going to take a look at it tonight though, and make sure it is not a fire hazard!
Posts: 1,677 |
Originally posted by jerseycat10: yeah, it was weird, I went back later to do the search, and it worked fine. I am having intermittent connections at work, so mayber that was what happened. At any rate, I just made an appointment tfor next Tuesday to have the safety recall performed. They said it would be free of charge, and that I could not pick up the resistor pack and install it myself because it is a safety recall and it is illegal to do that. I am going to take a look at it tonight though, and make sure it is not a fire hazard!
Well, turns out the 99+ contours are not covered under this safety recall. I bought the resistor pack for $7.85 at my friendly local Ford dealer, and installed it myself in about 5 minutes, and my A/C is back to normal! Excellent! Requires a 7/64 hex wrench.
Posts: 7,117 |
MY FORD DEALERS SUCK FOR PRICES!!!
I had to pay over $15 for that freakin' part!
Everybody else gets DMDs for $45, I have to pay $60 if I want one. Next think you know the $80 metal impeller water pump is gonna cost me 150 freakin' dollars!!
I'm also having to pay $4 for a spark plug, what are you payin'?
