Posts: 8 |
I have a clicking/rattling sound on the passenger side of the engine zetec VCT. I took the belt off today and the noise is still there. Its kind of like a lifter noise but the car runs just fine. Also the noise is not as bad when it has warmed up. Could it be something to do with the vct? I have no check engine light. Its an atx
99 Contour Zetec
Posts: 32 |
mine has done that ever since i bought it. it still runs. as long as it continues to run, i really don't care, though it makes my car sound retarded. :rolleyes:
1995 Mercury Mystique GS 2.0L Zetec, MTX 10% dents all around its not my fault its teal!!! it was cheap!
Posts: 594 |
most likely it is the timing belt hitting the cover. This normally only happens when the car is cold. there is alot of information on this in the zetec forum if you search. This is a fairly normal and frequent amoung the cars. you can either take the cover off, put washers in as spacers or live with the problem, your choice
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 1,692 |
Thanks for the reminder... I still gotta remove the stupid cover on mine. I've been meaning to do that since last summer :p
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 1,268 |
Can removing the cover cause any problems?? Like dirt getting in something that it shouldnt? If not it would look better without it, I would think.
-Ken V. psycho_bass@hotmail.com My Car
Posts: 2,523 |
I've had mine off for a few months. The 98+ cover isn't a completely sealed unit, so any dust that can get in from the bottom side would still make its way to the gears and all.
I'm not sure how protective the '95-'97 unit is. From the diagrams I've seen, it looks like more of a monster to take off, so it may be more protective.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 8 |
Thanks, I'll check it out
99 Contour Zetec
Posts: 1,969 |
What year is your tour?
If its a later model, it probably is not the belt cover as they were revised later on. (I'm guessing a later model since it's a VCT).
It may be the belt tensioner- mine is obnoxious when cold.
Kharma is very real and she is one mean b!tch.
Posts: 8 |
Its a '99 and has 36k miles
99 Contour Zetec
Posts: 1,969 |
Here's a garage mechanic's trick.
Take a small section of hose or tubing and holding one end of the tube to your ear, move the other end near where the sound is.
This will help you isolate where the sound is coming from. Them you can tell what part is the most likely culprit.
To check the belt tensioner, pull the passenger wheel and wheel well off. The tensioner and pulley will be staring you in the face.
