SVTour98
you shouldn't be rubbing in the back like that. especially on stockers (and btw, the 17s u have are equivalent in size if not a tad shorter than the stockers so u shouldn't rub with them either).
yeah, I know I shouldn't and I know ford should have replaced the springs when I brought it in, but you know ford dealers...
In fact, when I brought the car in the 1st time, they asked if I had an aftermarket suspension because the wheel well gap was noticably smaller in the rear than the SVT should be, then after looking at it they tell me it is in spec.
The new tires are a tad larger (about 1/4 inch or so, so not that different.) I did have the car 4 wheel aligned 1 month before the upgrade to koni's and H&R and then again, when I did the upgrade. The shop did not charge me for the second alignment since they had done the 1st.
Like I said the stock springs and struts were just shot. When I had my brother and dad in the back of the car, the rear end sqatted so much the my tire actually tucked into the wheel wheel. Once the new springs and struts were on, even with both of them in the car, the rear only drops about 3/4 of an inch. I am very happy the the suspension work fixed it.
