#8599 04/04/02 02:18 PM
V
vudusvt Offline OP
V
Hey guys/gals,
I'm flushing the radiator this weekend. Has anyone used Peak antifreeze? It comes "premixed"- no need to add water. What's the consensus- recommended, not recommended?
TIA
-Chuck Dienzo
"Taxation WITH representation isn't so hot either!"
Black 98.5 SVT, lightly modded
Born on 3/16/98
#8600 04/04/02 02:31 PM
Kind of a rip-off. You pay the same price as unmixed, but get the same amount. Save your money and mix it yourself. If you want your car to run cooler try this [URL=http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3338&prmenbr=76&lastcat=]
It works well, I use it in my 81' Cutlass, it has a chev. 350 and always ran hot. Now it runs at about 165 deg..
1998 Silver Frost SVT
Purchased 01/10/02
Mods so far:
-Fidanza aluminum flywheel
-Clutch upgrade
-Clarion ProAudio system, DSP, 13 Band EQ
Future mods:
-Intake upgrade
-Performance plug wires
-Autolite double platinums
-Konig 18 X 7.5 Toxxin's
-Koni's and Eibach coil overs
-Rockford amps, 3 12" Rockford subs, etc..
(Just needs to be installed)
#8601 04/05/02 02:37 PM
I also believe they mix it 50/50, which is weaker than the better 60% antifreeze/40% water blend. The 60/40 gives better heat and cold protection.
Also keep in mind when you flush the radiator, you'll have water in the lines when you're done. So the key is to put all the antifreeze you're putting in first, then enough water to fill. Therefore, you'll end up even weaker if you use pre-mixed.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
