Posts: 299 |
Every time i rev my car passing minivans, or luaghing at civics, i get a very harsh sulfur smell, car runs perfect, although i do only get 250 miles to the tank. I did a search and most people have said its due to a bad cat, i just want to make sure that it can't be anything more serious, and find out if its covered under ford's warranty. my car has 43,000 miles on it (check sig), and if so, can i take it to any ford dealership, even though i bought from a joe shmoe used car dealer?
Silver 1998 Mystique LS (v6)...ATX  Removed Emblems, limo tint, painted calipers. Premier P630 HU with 4 Pioneer TS-A6895 Speakers with 10' Sony sub (yeah i know, i'm cheap) Commando 501-S Alarm
Posts: 299 |
SON OF A BIT....damn, i posted this topic first, and it said it had an error, so i went back and rewrote the post...sorry i normally hate people who double post.
Posts: 154 |
Can't you just delete the other one since you posted it? And yes, it does sound like the main cat is the culprit in regards to your question.
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
Posts: 335 |
I had this problem too. When I had my car on the dyno it was running really rich. After that it started smelling like sulfur under normal (slightly spirited) driving. I *****ed to Ford that something was wrong, but their computers told them nothing was wrong. They finally said that my MAF sensor was on the far end of the scale and that they really had to "fight the system" to replace it. After that it has run fine. I figure my cat is bad now though from having raw fuel in it. Really hard to convince Ford to replace my precats and cat.
Current Cars:
2000 CSVT #398 / 2150 - TRed
85 CRX si with a suspension harder then Ron Jeremy on Viagra.
Posts: 3,950 |
Posts: 1,701 |
Proabably running rich. Marginal O2 sensors or MAF causing PCM to put in more fuel than is needed and decreasing your mileage. Any CELs?
Posts: 299 |
why yes....the CEL cycles on at least once a week. it just came on and thats what prompted this post. The car drives great so it has to be something emmissions related, but i wish i could get better MPG and drive without smelling like asss.
Posts: 174 |
It?s not your cat (yet). At WOT you engine will go into open-loop mode. If your engine is running a bit on the rich side in closed-loop, then it will go way rich in open-loop, rich=smell. Check the basics first, have the injectors cleaned (not with the fuel tank junk), air filter, wires, and plugs. Do a scan for codes and check the O2 sensor(s) output. Also, the upper intakes on these cars tend to get very fouled up with carbon from the EGR. This can interfere with the air fuel burn and produce a rich condition.
good luck jeff
Posts: 136 |
Get out from behind the Volvo you've been following.....
1999 Black SVT #2639/2760 on 08/11/1999; w/18" OZ Racing Superleggera's, Yoko Paradas. MSDS Headers,Quaife LSD, Borla,KKM,chipped,DMD,Baer 13" Track rotors. Lowered/HR and Koni's; HPP RSB
Posts: 620 |
The sulfur smell indicates that at least one of your cats is working just fine, but that your car is running rich.
I would try to get the codes scanned. It could be due to one or more bad O2 sensors, as others have suggested. My car was making the sulfur smell for over a year before the O2 sensor became bad enough to trigger a CEL. After replacing the O2 sensor (bank 1 upstream, in my case), the CEL and sulfur smell went away and I passed the emissions test (back in Nov of '01) with flying colours. However, the smell has recently started coming back so I am going to go ahead and replace the bank 2 upstream sensor this summer.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
