Posts: 89 |
hi all i was trying to replace my pvc vavle and could not get it out of the engine the area were it is located is hard to pullit out do any one have any suggestion on getting it out also since i couldn't replace it i tryed putting the hose back on and couldn't need help asap 97 4cyl 62,750 all powered also can any damage be done while the line is not connected????
R.A
Posts: 1,165 |
All ford dealerships will replace your pcv valve at 60,000 miles, at no charge parts or labor. It's absolutely free. And at 63,000 they should still do it, your only one oil cahnge late. I don't know about it running with it out connected, I don't think it will hurt anything, but i could be wrong. Anyways, just go in there tell them you have a little over 60,000 miles and your ready to have your pcv changed at no charge. Simple as that.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 89 |
is that even if i tryed to replace it my self the pipe would not line back up ???
R.A
Posts: 12 |
Search of this database will reveal the Dealer will indeed replace the PVC for free BUT only if you pay for 60K service which runs into the hundreds of dollars. I had no trouble replacing mine with a long screwdriver to access the upper reaches where it is located. Remove it from the intake manifold and it will fall into your hands from its connecting line; replace the valve in the line and then insert it into the manifold with the screwdriver.
Posts: 1,165 |
Originally posted by mikcarsd: Search of this database will reveal the Dealer will indeed replace the PVC for free BUT only if you pay for 60K service which runs into the hundreds of dollars. I had no trouble replacing mine with a long screwdriver to access the upper reaches where it is located. Remove it from the intake manifold and it will fall into your hands from its connecting line; replace the valve in the line and then insert it into the manifold with the screwdriver.
Incorrect. I did all the other 60,000 miles maintenance myself walked in the dealer told them i needed the 60,000 mile pcv change, it took them like an hour, but i was out the door without paying a cent.
"The dealer will replace your PCV valve at 60,000 miles (except for Canadian and California models) at no charge to ensure the vehicle meets emission standards."
If they refuse, go to another dealership.
~Henry Ford
Posts: 89 |
mechanic put new one in but 30 min later it push the pvc out and i heard the hissing sound i took it back think the rubber grommet is bad i will keep you updated a promblemwith the metal pipe connected to the hose i quess???? driving me crazy
R.A
Posts: 12 |
99: Your anecdotal account cannot possibly invalidate the other anecdotal accounts on this board. You can only report your one single experience.
Posts: 12 |
99: Exactly my point. You can only verfiy your very own personal experience. You have absolutely no proof of what someone else went through and therefore, cannot speak on their behalf.
