Did you lower compression, or are you running 11:1?
If you didn't lower the compression that you are sh|t out of luck. You can run maybe 3psi or so, but above that you'll probably break something.
This question is probably best placed in the FI forum anyway, but the short answer is...turbo is better, but more than 10:1 compression is bad for either turbo or S/C, though the S/C would be a better kit IF you were bound and determined to run it on a 11:1 motor. You'd just have to use 100 octane gas all the f'in time.
See My Mods
